Things that do not work with custom templates
Custom post templates are great because they can be customized a lot. The problem that I have found is that it does not work with certain things:
-If I create an article (using custom post template) and I use smart list to list a list of h3, the content of the post is shown normal (smart list does not work). Is this normal?
-Disqus does not work with custom templates.
The rest is very interesting, Cloud templates gives a great customization flexibility, thanks!
+1 vote for disqus integration on custom templates 🙂
The cloud template which you use for a smart list should not contain the post content element, only the smart list element. A discussion about this here
– https://forum.tagdiv.com/topic/smart-list-block-see-the-entire-list/
Disqus doesn’t work currently with cloud templates. This may change in the future however.
Hello Simion!
Then, If I use custom template post, I need to create a template to each features not?
For example:
-1 template to review
-1 template to SmartList
-1 template to Post normal…
Is it correct?
Yes, that would be it. We have created some cloud single templates just for smart lists for example
– https://www.screencast.com/t/OZbpKsP7J
You can have as many templates as you want, for different situations.
