Hi, all my posts thumbnail is not getting generated when i activate TD Composer. thumbnail is not showing i have done with the setting in Block Settings all of them are no. and generated thumbnails from plugin as suggested in your forum.
By default our theme will generate thumbs for modules inside the blocks and grids, in this way the image will adapt and look well on all elements and viewporst you are using.
In some cases the images need to be regenerate in order to fit the module from block, for this you can use our guide form here -> https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
If this is not what you mean, please provide some more details and a link where I can inspect the problem.
