I can’t seem to get the thumbnails to load in posts/blocks (https://eygcmedia.com/). I have checked force full content and have the premium rss full text feed to post.
I also can’t get the homepage up on mobile. Its currently showing the default header with Newspaper logo and not the current setting I had implemented.
For images please make sure you have enabled this option from Theme Panel -> Post Settings -> Featured images => https://www.screencast.com/t/BIDW11v0
Also, please check if you have the thumbs enable from Theme Panel -> Block Settings => https://www.screencast.com/t/W7mJQNv3
Also, please do a test using only tagDiv plugins on a staging website, because there is a possibility, to be a plugin conflict, and see if the problem persists.
Also, I checked your website and seems to work well https://www.screencast.com/t/pUgkzJCf79J
