I have a problem with my thumbnails.
As you can see here – http://trucchiesoluzioni.net/soluzioni-94-ecco-le-risposte-a-tutti-i-livelli/ – the thumbnail size is wrong. It happened right after i used EWWW Image Optimizer to optimize media files (to increase pagespeed). Is there any way i can fix this without losing the optimization?
Regards,
Sebastian
Hello Podoseb,
Unfortunately, your plugin is not tested with our theme and we have no idea the theme behaviour with this kind of plugin. As you can see in our documentation, we have a list of tested plugins wich are tested and are worked properly with our theme, as you can see here -> http://screencast.com/t/VBkCEcYE Please try to use SEO Yoast optimization plugin because are tested with the theme and works fine without problems. If you want to display more levels in our theme and you want to adjust your plugin functionality to our theme for a good working and if you are not aware the steps in this regard, please consider hiring a freelancer or developer to do this for you because we cannot provide custom services at the moment, sorry!
Hello Podoseb,
For more information about how to make your website faster can find in our tutorial here -> https://forum.tagdiv.com/how-to-make-the-site-faster/ and the plugin that we recommend for optimizing the images is -> Wp smush.it and you can download from our tutorial.
Hope this helps!
Thank you for the message!
Another thing. Is there any tutorial to setup the forum too? Because i just can’t find a way to enable breadcrumbs in forums: http://trucchiesoluzioni.net/indice/forum/giochi-e-app/giochi-per-android/
Thank you for the response.
Hello Podoseb,
Please check this topic because here you can find the answer to your question -> https://forum.tagdiv.com/topic/no-breadcrumbs-in-forums/ another user has had this problem and he has succeeded to resolved it.
For more information about bbPress settings, please consult this documentation here -> https://codex.bbpress.org/step-by-step-guide-to-setting-up-a-bbpress-forum/
Hope this helps!
