Thumbnails problem on my website
Dear All,
I’m facing a real issue with my website. In the front page of my website dosen’t show the Thumbnails properly. Link of my website : nessahra.com
Could you please help me please to fix this problem ?
Best regards,
Sam
It seems you have a lot of errors on the website – https://www.screencast.com/t/qrNkzXLm
I suggest you disable all your plugins except Visual composer, clear any caching installed, then check to see if the thumbnails are displaying properly. In almost all the cases some problematic plugins are causing issues.
Also it is recommended to use this caching plugin with the mentioned configuration
@Simion: my website is much better now 🙂 Thank you very much for your help.
