Thumbs problem feedback
Problem Description:
Description of the problem: When I open all the options under block setting——Thumbs on Modules/Blocks, the system will automatically generate a Thumbs image of the corresponding size, which is no problem. However, all the thumbnails generated by the system will be saved under the wp-content-uploads folder with a single image size, which will cause the uploads folder to be very large, as shown in the figure below:
Suggestion: The original Thumbs of the newspaper are saved under the wp-content/upload folder, and other Thumbs images can be saved separately in a new folder
In this article,
https://forum.tagdiv.com/theme-thumbs/
It’s said that
When you decide to post content on your website, the theme automatically generates thumbnails from the featured image to display the content on your pages in an attractive way.
Now I want to know how to delete the thumbnails that are automatically generated by theme?
We do not have an option to delete them. You need to do it manually. Sorry!
