Top Block on posts
I have an important question : is it possible to put the featured image, the title and the review in a block ?
Exemples : https://puu.sh/Bp8c7.png
https://puu.sh/Bp8cu.png
https://puu.sh/Bp8cM.png
When i try, the title is too high for the image and the review is at the bottom of the page
I can’t find a solution or an adequate template for it, is it possible to edit a post with TD Composer ? I don’t find this solution, have you got a CSS that can help me, thanks a lot, this design is very important to me !! 🙂
What do you mean exactly by putting them in a block? The default reviews looks like in this post for example
https://demo.tagdiv.com/newspaper/td-post-why-tech-accelerators-may-soon-be-as-irrelevant-as-an-mba/
You can edit post templates with the composer, this is an option since the cloud library plugin was introduced a while back
https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
Using Cloud library templates the reviews are split into three different element, you can place them in any way possible in the post template
https://www.screencast.com/t/QDN0mzGMP
Maybe this is what you want to do.
