Does anyone have problem while trying to Translate Newspaper theme and Save Settings.
While i try to Save Settings the bar keeps circling and nothing happen.
Please check the console when you hit the save button and see if there is an error. With right-click -> inspect -> console -> select the error in the tab network -> preview, you can see the cause and check the suggestion from here https://forum.tagdiv.com/topic/newspaper-theme-panel-settings-are-not-being-saved/ -> https://community.godaddy.com/s/question/0D58W00007ggvUDSAY/403-forbidden-error-not-sure-why
it shows this message in console: Failed to load resource: the server responded with a status of 510 ()
A 510 response appears to be more related to a server configuration issue rather than something originating from WordPress.
The issue with certain files leads me to suspect that modSecurity or a similar component is at play, and its configuration might need adjusting. Your host probably needs to assist you with the modSecurity setup.
