Translating problems
How to translate Search in theme.
https://6.test1.lt/
I need to translate these phrases its in search:
SEARCH FOR AN ARTICLE
Type in your search query
You need to edit the search page -> https://i.imgur.com/yZ19TKm.png -> https://i.imgur.com/oeP0zIX.png
It worked Thanks!
Another question 🙂 How to make a header sticky? 🙂 Maybe not whole header but only menu. Is it possible?
You need to set the menu in a new row -> https://i.imgur.com/0HE5cM8.jpg for the sticky menu and after doing the changes.
Yah Great! But again i have a new question and problem. I want to make page multilingual.
SO i’m using polylang plugin.
I made diffrent menu. But i cant make a diffrend language Header. How to do it?
Is it possible?
Hello @zenka!
Unfortunately, Polylang plugin, has not been tested with our theme and therefore, we cannot say for sure if it will work or not as expected with the theme, sorry! Also, we cannot provide support for untested plugins.
We recommend WPML plugin for translations: https://forum.tagdiv.com/using-theme-translations-together-wpml/
Hello my dear friends, i have another one problem. Social buttons on mobile menu. How to disable some of them and add links to others. Willing to hear from you soon ! 🙂
Hello @zenka!
Please provide more information about what exactly you need to achieve and your issue, including screenshots or a video, and your website link.
https://ibb.co/D7XM5Df
its a mobile menu. SOCIAL LINKS. HOW TO EDIT IT 🙂
Hello @zenka!
Social media icons can be disabled/enabled by filling the fields Newspaper -> Theme panel -> Social Networks with the unique URL.
Hello, i’m trying to translate some words in other language Like in Lithuanian. But its not working.
When i’m trying to edit i’m getting this error
https://ibb.co/8BrCMZC
https://ibb.co/0fSFPL0
Please help 🙂
For this error, please check this topic: https://forum.tagdiv.com/topic/error-at-zones-6models-1dom-the-model-does-not-match-the-content-currene/, please use a revision of the page/template.
Sorry but it not helped at all.
How to translate this page? Can you give instructions? 🙂
Hwello,
First of all, you have to solve that error, only after that, you can translate the elements with tagdiv Composer.
In the current situation, you cannot edit any element, that’s why I told you to use a revision of the page.
I would glad to. But its search result. and it dont have any revisions. I cant edit this page only with builder. Please tell me how to solve the problem 🙂
– admin url and credentials
– cpanel url and credentials
Hi guys i have new problem. I need to post text would be set without important tag. And i cant find it. Please help 🙁
https://0.test1.lt/kai-viena-ryta-prasideda-karas/
when inspect paragraph
i see
.tdi_104, .tdi_104 > p, .tdi_104 .tdb-block-inner > p {
font-family: Montserrat !important;
font-size: 17px !important;
line-height: 1.7 !important;
font-weight: 500 !important;
this style should be not important where to change
Please provide some screenshots of what tags you are referring to.
https://ibb.co/ZG2qbzy
there is a photo link you have 🙂
Unfortunately, I fully understand what is the problem.
This is the style for Single Post Content.
OK so i need to it to be not important. Where can i find the file to edit?
can you say for me /public/…
I don’t understand what the problem is, that’s how it works. This is also the case with nope pre-built websites https://i.imgur.com/UHNwdm1.png -> https://demo.tagdiv.com/newspaper_center_pro/2022/01/07/td-post-the-most-popular-celebrity-name-list-of-the-millennium-is-finally-here/
problem that im using plugin for blind people. and there is function to size text up. and it going thruw the style. And becouse of font size :17 !important i cant change the size of text. I need to find this place and remove !important.
Can you do it? Or can you tell me where to find this line with code?
Hi zenka,
Unfortunately, our theme set the important element when the font is set on elements. For example if the font is set on default, then there should be no important, but if there is a font set, then that element will be applied. What I mean is that the important is set using js for the elements where is used a different font size than the default one. Also, most of the CSS from our theme is generated by the js.
My suggestion is if you are using a single post template to edit it with tagDiv Composer and remove the font from post content like this -> https://i.imgur.com/Une7inC.png
Thanks! its worked perfectly 🙂
Viewing 25 posts - 1 through 25 (of 27 total)
