Trying to move review block above ads section
just can’t seem to drag above it. whats the solution here?
https://imgur.com/a/NStSohz
Please add a new row and add there the review block.
that will place the review block below the ads block
You need to drag the ad box element then. Please provide more details about your issue. Can you not drag any element?
the entire written content including the adbox is one element.
Unfortunately, I don’t understand your issue.
Please provide more details and a video.
https://youtu.be/2y_8CW7__sU
explained with voice
So as a solution for you, if you want to have an ad box after the review block, I recommend deleting the code for the ad bottom from the single post content and adding the ad box element where you can insert the code from the ad bottom.
how do you delete it
You need only to copy and paste the code from here to here -> https://i.imgur.com/sgCauel.png -> https://i.imgur.com/b6KRgnA.png
Thank you i figured it out.
