Two différents contents sections in the same post template
I would like to know if it’s possible to have two post content section in the same template in the TDComposer.
I would like to have a first part of my post in a full width format to put a comparison chart and below, have a 2 columns format with post content on the left and the sidebar on the right.
Is it possible to do this? If yes, which block to use on my template ?
Ty in advance.
Nobody knows how to do that ?
  • This reply was modified 8 years by ouebflow.
Hello ouebflow,
Notice that you can try using the Single Template Library from our Cloud Template and use a Blank Single Template which can be customized by your desired using the TD Composer. Check the plugin documentation from here -> https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
Thanks for your reply but I don’t find block that I can use after in the editor with 2 differents posts section (one full width and below 3/4+1/4)
When I customize a template and put the “post content” block 2 times, when I write something in the editor, it appears 2 times when I publish the post.
I need to use this template for many posts and I don’t want to create a new template each time I need it for a different comparison chart. I could use the “html code” block but I can’t modify it in the editor.
Hello ouebflow,
Please provide some mockups and useful screenshots so I can identify what exactly you want to achieve.
2 sections
Here is what I would but with the possibility to manage the two part in the wordpress post editor to add the shortcode of a comparison chart and put the buyer guide with the sidebar below.
In my head this is :
Intro
Full width comparison chart
3/4 buyer guide ! 1/4 sidebar
With a template I can edit in the blog post editor without create a new template for each buyer guide.
Hello ouebflow,
I guess that you want to achieve something like this -> https://www.screencast.com/t/uSZlYSqeVW Use a black Post Template from Cloud and customize it with TD Composer.
Hope this helps!
It’s something like that yes but must I create a new template each time I want to put a different comparison chart or can I add it when I edit a new post ?
Hello ouebflow,
Sorry, but please notice that another solution does not exist in this case. If you want to have a different chart for each post you should create more single templates.
