Two problems with headers
I have 2 Issues with headers:
1. Although I mark the header as h3 in the editor, it is still an h2 in the source code, see screens below:
https://ibb.co/dMjD17W
https://ibb.co/rHc59cM
2. Where can I Change the global setting for “Similar Articles” and “More from Author” from h4 to h3 ?
  • This topic was modified 7 years by wdziedzic.
1. Were Did you set the code with <h3>???
2.Unfortunately those blocks do not have this option ( to change the title tag (SEO )) like page title -> https://www.screencast.com/t/01z2DVae6
Hi.
1. I set it within a given article
2. I didn’t mean the SEO title but the section below the article with similar artciles and more from same author:
https://ibb.co/zsWSGXX
Cheers
1. So you set the h like this https://www.screencast.com/t/GOA6EkszX -> https://www.screencast.com/t/IbfHwWp8
2. The only wan to change the h4 in h3 for “Similar Articles” and “More from Author” is if you change this in theme files; the path to that file is wp-content/themes/Newspaper/includes/shortcodes/td_block_related_posts.php
-> https://www.screencast.com/t/usR9gNxxS7E
-> https://www.screencast.com/t/IPbrFgyrrTWF
1. Exactly, I set one thing in the editor (as we see on screen 1. ), in this case <h3> but what I get in code (As we see on screen 2) in this case an <h2>
2. Got it, changed, works
  • This reply was modified 7 years by wdziedzic.
Short update to 1. Just found out that this issue is only when it is a smartlist – maybe this will help to find the solution
If is a smart list then will need to follow some rules: The Smart List will use the title to generate the list. In our example, we are using Heading 3 for Titles and we need to choose the same size in the Smart List settings section from Title tags to be able to generate the list.
-> https://forum.tagdiv.com/smart-lists/
I think that is way is not change the h4 in h3.
