two questions: Flex Block-1 filter and top-level menu
Flex Block-1
I’ve got a category page template with the Flexbox-1 component added in, sorting by “latest”. For some reason, it always skips the first 5 most recent items and starts showing the 6th-most-recent post. I’m guessing there’s some offset setting somwhere? I can’t find it. How do I make it show ALL most recent?
Top admin menu
I’ve installed Newspaper on a few locally-hosted sites, and every time I have, when I’m logged in and viewing the site, there’s a narrow and handy top-level menu with all sorts of administrative commands, included “edit with TagDiv Composer”….
However, I’ve just launched a site hosted on the official WordPress.com hosting option, and, when using the Newspaper theme, that menu does not appear. Is there some config setting I can make to allow that menu to appear?
I found the “offset” setting in the Flex Block 1 – which seems like it should’ve solved my issue – however, when I put the offset to 0, the Ajax “infinite load” feature breaks – it keeps cycling through the same 4 items over and over.
You need to let the offset empty without a number or space.
Also, please let me know if you use jetpack plugin, if yes, please check this guide -> https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
