Uncaught Invalid data Current state has involved an issue when changing IMAGES
Hi, even with the latest 10.3.3 versions and below with WPBakery 6.1/6.2, editing PAGES with the TD COMPOSER produces various type of errors. We have only TagDiv plugins activates with WPBakery. Nothing else.
Following the system info details:
Theme version/DB version: 10.3.3
Server software: LiteSpeed (no cache plugin enabled)
PHP Version: 7.2 (we experienced the same problem with 7.4.4)
post_max_size: 256M
max_execution_time: 90
max_input_vars: 1000
SUHOSIN installed: false
mbstring: available
GD library: available
WP version: 5.4
WP multisite enabled: No
WP Memory Limit: 40MB/request
WP_DEBUG: False
Caching plugin: No caching
allow_url_fopen = On
The same configuration works if we disable PAGES from WPBakery Post Types.
ON ENTER PAGE USING TD COMPOSER (console errors):
load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2 Uncaught Error: Syntax error, unrecognized expression: #/
at Function.ea.error (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
at ea.tokenize (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
at ea.select (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
at Function.ea (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
at Function.a.find (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:8)
at n.fn.init.find (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
at n.fn.init.a.fn.find (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:8)
at a.fn.init.n.fn.init (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
at new a.fn.init (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:8)
at n (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
ace.js?ver=28832a33217c23aa6f76cdf3fc3c1388:1 Uncaught TypeError: n is not a function
at n (ace.js?ver=28832a33217c23aa6f76cdf3fc3c1388:1)
at a (ace.js?ver=28832a33217c23aa6f76cdf3fc3c1388:1)
at r (ace.js?ver=6.2.0:10)
at Object.a [as require] (ace.js?ver=6.2.0:10)
at post.php?post_id=175&td_action=tdc&tdbTemplateType=page:2922
at dispatch (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:3)
at r.handle (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:3)
ON IMAGE CHANGE:
Uncaught Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
Uncaught TypeError: Cannot read property ‘data’ of null
at Object.<anonymous> (backend.min.js?ver=6.2.0:10)
at i (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
at Object.fireWith [as resolveWith] (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:2)
at x (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:4)
at XMLHttpRequest.c (load-scripts.php?c=0&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4:4)
js_files_for_wp_admin.min.js?ver=28832a33217c23aa6f76cdf3fc3c1388:15 Uncaught Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
There can be some problems between tagDiv Cloud library and WPBakery, we recommend to use only one of them with tagDiv Composer, please disable WPBakery clear all cache and try again.
Let me know the results!
Hi Calin, we have done what you suggested (the differences where in few minor settings) but nothing has changed.
We suspect some problems at higher levels with PHP 7.2 in a LiteSpeed environment and your procedures. As we said the WPBakery works well only if it isn’t enabled in the PAGE post type side by side with you tagDiv editor.
If there are still some problems, please provide as many details and screenshots you can to try to recreate the problem and find a fix.
Can you give us the email where we can send the credetials of the development website where you can check the problem? Thanks
You can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
