Hi thanks for your attention, we had not read the notice in the forum until today and by mistake we have updated composer and now we can not make any changes in our blog because we have design problems.
The Composer plugin is the one that incorporates the theme.
How can we solve it?
It does not work
“Otherwise there will be layout issues that will force you to re-create your pages even if downgrading the plugin back to 5.1.1”
This was also always specified in the Visual composer update guide
– https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
The new version of Visual composer must be tested properly first with the theme, and then included in the theme package and officially supported. This will ensure the best functionality between the two.
Fixed! We degrade the plugin version via FTP. Thank you very much for your attention.
