Uninitialized string offset
I get this error message at the beginning of every article:
[img]http://up.picr.de/34040307aq.jpg[/img]
And that is the part of the code:
// return if the ad for a specific spot id is empty
if (empty($ad_array[$spot_id][‘ad_code’])) {
return ”;
Row 39 starts with if
If you are using any plugins, please try to deactivate them, and try again.
Please provide some more details and screenshots, or a link to the website where I can see the problem would be very helpful.
here an example link https://www.hrs.com/pl/serwis-prasowy/informacje-prasowe/firma-hrs-zajmie-sie-digitalizacja-globalnego-programu-hotelowego-airbusa.html
You will see the error message in the beginning of the article
There seems to be an ad that is no longer working.
Please check if you have some ad in Newspaper>Theme panel>Ads >Article top ad ( https://www.screencast.com/t/qSwFJWeKSi ).
Also check if your WP_DEBUG is set on false ( documentation ).
Let me know how it work.
Article top ad was empty, setting debug to false solved the problem, thanks!
