Uninstall Demo Problem
Hello.
I installed the Beauty Blog demo and played around with it. Then I uninstalled but my page is still constructed with the demo. Did I did anything wrong? Please help.
Uninstalling the demo, or installing a new demo should remove the previous demo completely. The website should be as it was before installing the demo
– https://forum.tagdiv.com/installing-demos/
So the homepage should be removed as well. Maybe it’s a caching issue, try to clear the cache, also force refresh the page in the browser (Ctrl+Shift+R). Let us know.
What exactly does “the website should be as it was before installing the demo” mean? Does that mean that menus, pages, and posts added AFTER the demo was installed will also be uninstalled? What about Cloud templates? What about reusable blocks? I want to clear the decks of remnant demo styling because it’s not TagDiv compliant and I want to be working with clean slate. But I don’t want to undo the other work.
I realized I should probably start another topic. I did: https://forum.tagdiv.com/topic/what-exactly-is-uninstalled-when-you-uninstall-a-demo/#
