Hello gwendal44,
Most likely, you do not follow the right steps in this case. First of all, you should make a full backup to your database and then, you should remove the old version and install the theme via FTP way, according to our documentation here -> https://forum.tagdiv.com/install-via-ftp/ Try to follow all the steps from this tutorial and then, clear the caches and check the results.
