I’m using the new Urban Explorer Template and have set the Sidebar to be on the right side in the Theme Panel, but it’s not updating to that setting on the actual posts.
I’ve searched the guides/documentation and have discovered that I should be able to set the post template on each individual post for the sidebar to be on the right, but I’m not seeing that option at the bottom of the posts.
I’ve also made sure the CPT and Taxanomy settings are set to the right sidebar.
Am I missing something, or do you have more information on how I can set the sidebar on my posts to the right instead of the left?
If you want to create the sidebar in Appearance -> Widgets and set the sidebar on posts, using the element from tagDiv Composer, Widget sidebar https://i.imgur.com/e1FPdYU.png -> https://i.imgur.com/q20UCZf.png -> https://forum.tagdiv.com/sidebars-tutorial/
I want the sidebar to be on the right. How do I do that?
