I’m encountering several issues that I’d like assistance with, especially as I’m planning to launch the website tomorrow or the day after.
Header Issue (Desktop): The header works perfectly on mobile across all categories, but on desktop, it displays as black in the categories. It used to look fine, so I’m unsure if this is because the site is in maintenance mode or if there’s another issue.
Countdown Plugin (Mobile): I used a countdown plugin earlier, but I removed it since the free version only displayed 10 days. I had placed it in two specific categories, and while I removed the element from the editor, it still shows up on mobile (but not on desktop). I’m unsure how to remove it completely since it no longer appears in the editor.
Sticky Menu Issue: I fixed the top menu as sticky, but the bottom column (where I display the “Latest News” ticker) also became sticky. This is less urgent, but I wonder if it’s possible to make just the top menu sticky without affecting the bottom column.
Post Design: I’m currently managing post layouts through the theme panel. I downloaded and customized some templates but wasn’t satisfied with the results. Is there a way to modify the current post design without applying a new template? Perhaps using a blank template or another method?
I’d really appreciate your guidance on these issues, as the launch date is very close. Thank you so much for your support!
Best regards
Aquí tienes el mensaje traducido al inglés:
Ah, I forgot to mention one last thing: Is it possible to create a third menu to include both the top menu and the main menu in the mobile hamburger menu? In other words, to have both menus integrated within the hamburger menu.
Thank you again for all your help.
Please check it in the tagdiv Composer.
Check in the Composer and mobile viewport, and delete the entire element from there, too. Clear all the cache and try again.
Place the ticker in a new row and ensure it is placed in the content zone, not the header zone. Please follow the video to see where you can find and edit/build your sticky header on mobile and desktop, too: https://www.screencast.com/t/l6v2Belt
Sure. You can install a blank template, customize it in the tagdiv Composer, and assign it to your posts. More info here: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
I hope that helps you!
