There is a similar bug here:
https://forum.tagdiv.com/topic/urgent-pagination-does-not-work/
In our case, we don’t have Facebook plugin.
This is a very urgent bug. I can disable any incompatible plugin if it is known.
The web pages that you can observe the problem are here:
http://hayatdefteri.com/page/2/
http://hayatdefteri.com/page/3/
This topic was modified 13 years by
mertnuhoglu.
Hi Marius,
Different pages show the same posts. Look at the following screenshots:
http://dl.dropbox.com/u/103580364/temp/000737.jpg
http://dl.dropbox.com/u/103580364/temp/000738.jpg
2. and 3. pages are exactly the same.
Hi, I deactivated all the plugins but the problem still continues. Please check the following two pages. They are exactly the same:
I set the listing as infinite scroll. So the pages are not visible anymore.
If you want give me access to your WordPress to try to fix the pagination. Send via email at contact@tagdiv.com
I still have the problem. I have just found out the post listings are repating even in infinite scroll mode. See here:
https://forum.tagdiv.com/topic/posts-are-repeated-in-infinite-scroll-feature/
