Usage of two templates for web / mobile
currently there is no option to adjust the number of posts for web differently for mobile theme.
(this has been added to the to-do list I have been told).
However since this might be a while, I was hoping to create two different templates, one for the full site and
one for a mobile viewport.
How would I need to proceed ?
I figure I can use the wp_is mobile function built into wordpress but was wondering if anyone has tried something like this and how feasable it would be.
Hello NickDeBaerdemaeker,
Unfortunately, the theme does not have any such an option for this functionality, sorry! The theme has two ways for mobile devices. The first one is set up by default – General Responsive Mobile Theme which displays you the desktop layout in responsive mode and which can be customized from TD Composer when you edit your page, like this -> https://www.screencast.com/t/4FV0ZWPKTyAc and the second option would be to use the Mobile Theme plugin, according to our documentation from here -> https://forum.tagdiv.com/the-mobile-theme/
Is there a way to edit the mobile theme then so it does look a bit more like the full web site ?
For instance would it be an option to install a second copy of the newspaper theme but adjust it to our specific mobile needs, and make the site use that theme when it detects mobile devices ?
to edit it with the tagdiv composer I mean…
Hi NickDeBaerdemaeker,
Unfortunately you can’t use TD Composer for mobile theme, but you can use flex block and set different layout in function of device :
On desktop: https://www.screencast.com/t/6HKNJjl35i
On mobile: https://www.screencast.com/t/Ik42eacS3DgK
Also you can read this topic: https://forum.tagdiv.com/topic/set-different-post-number-for-web-landscape-portrait-tablet-mobile/
  • This reply was modified 8 years by Calin.
