Use Composer blocks with Custom post types
I’m creating a custom post type and I’m wondering if there’s a way to use the blocks offered in Composer? like with shortcodes or similar? Either by putting them in the content editor or a way that I can include them with PHP?
Unfortunately, you can not modify custom post types with TagDiv Composer and you can not use cloud templates for them.
For more information about that, please check our documentation here: https://forum.tagdiv.com/custom-post-type-support/
Thanks for the reply, but that was not what I meant. I want to code the page for a custom post and I’m wondering if I can include blocks from Composer through the code?
We don’t recommend you to insert some blocks into the content of posts.
I can help you with some information which can guide you to achieve what you need.
Also, you can check those topics from here:
https://forum.tagdiv.com/topic/how-to-create-a-custom-single-template/
https://forum.tagdiv.com/topic/news-ticker-on-all-pages-and-posts/
Check our documentation for developers here: https://forum.tagdiv.com/developer-info/
Please note that for post content(CPT or default) you can not use TagDiv Composer.
For customization and other services you can contact our custom work team here and they can help you more to achieve what you need: https://tagdiv.com/premium-customization-services/
Hope that helps you!
