USERS HAVE PROBLEM WITH REGISTRATION
When a user registers using your theme, they’re asked to generate a password via email, but when they try to generate it, they see the WordPress interface instead of my website’s interface. How do I fix this? I don’t want them to see that it’s a WordPress theme; I want everything to be done smoothly from my website’s interface. Isn’t there also a way to generate the password beforehand instead of having to access their email?
You can use the element “Page login/register” https://i.imgur.com/CKLfaL0.png. This element can be set with the tagDiv Composer in a page that will be used for login and registration. You can combine it with the element menu login that allows you to set the links for login/register pages – https://i.imgur.com/fOUowam.png. To use those elements, you need to have the tagDiv Opt-in Builder plugin installed and activated.
