I remember this used to be a feature and somehow the template doesn’t exist anymore. Can you share how one can use it again? https://demo.tagdiv.com/newsmag/td-post-10-of-the-most-visited-countries/4/
You need to use the smart list from tagDiv Composer, inside Single Post Content ->
https://i.imgur.com/dbipPWQ.png according to the documentation https://forum.tagdiv.com/smart-lists/
Also, you don’t need to use the classic editor, you can use the Gutenberg editor, which is the default editor for WordPress and select/add the element classic https://i.imgur.com/9sWuCtW.png to add the smart list.
Also, please make sure you have the same heading, in the post editor and in the smart list element, please check this video -> https://www.screencast.com/t/BuFFxQKgj
Hi! Thank you for the response, and my apologies – maybe I wasn’t clear. I am able to use Smart Lists through Gutenberg. Just that I cannot find this particular slide-style.
I understand that we have 6 templates / styles of Smart Lists, but none are this way which allow a reader to swipe the entire content.
I’d really appreciate it if I can make the content & image slide instead of the pagination style.
Looking forward to hearing from you!
That type of smart list is available only for Newsmag. Those are for Newspaper -> https://i.imgur.com/2kmJNhP.png https://demo.tagdiv.com/newspaper_pro/
Ah!
Thank you for letting me know, Anamaria. Wish you a good day ahead. 🙂
I am writing in again — I’ve tried in vain to find a plugin or something similar, but the Newsmag Smart List 1 is something I’d really like to implement but am using Newspaper (the smart lists aren’t so great on this one!).
Is there a possibility of adding a separate code or adding this template into Newspaper please?
Unfortunately, as I said, the structure is different between Newsmag and the Newspaper
If you really want to change the way it’s working and looking,s you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
Thank you for understanding!
