After having learned that I could not use WP Bakery Visual Composer anymore (I learned it on your forum because I did not have access to it anymore) but TagDiv Composer, I notice today that I cannot use TagDiv Composer on posts but only on pages…
Thank you for confirming that I cannot use TAgDiv Composer on posts and in this case, what do you have planned for your users (are you thinking of your users?) who, like me, have more than 1000 articles and who have used WP Bakery Visual Composer to create them.
Best regards
Hello @RPFlu!
You need to import a single cloud template for your posts in order to edit them with the TagDiv Composer. Documentation here: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
You can assign the template to all your posts.
Hi @Bettina
Thank you for your answer but it does not answer my question…
Your solution is only interesting for people who create a website and who start from 0.
Using a cloud template to modify my posts with TagDiv Composer is a huge waste of time for me as I have to create several of them because I have more than 1000 very different articles that I will have to check one by one.
Why not be able to modify the posts directly with TagDiv Composer without creating a cloud template (like the pages)…
It’s good to think about your future users (customers), but it’s a shame you don’t think about those who have trusted you and who use your theme for years.
On the other hand, I also waste a lot more time editing my pages (more than 400) with TagDiv Composer. It was much faster with WP Bakery Visual Composer. Too bad for me, that it is not compatible with your theme anymore.
Once again, you have thought about your users…
Best regards
