using with polylang for multi language
Hello;
Is this fully compatitable with Polylang? I want to know if its possible to choose different layout per language?
I wouldn’t say fully tested by us, but there are users that implemented Polylang successfully. You could also check qTranslate. With WPML this is tested and works properly.
I created a page for my french homepage and am to use the page builder + latest post template but it won’t save. i bought WPML so that is what i am using
once i click save it goes back to page builder. am using the latest version
So the page you created does not save. What exactly is happening? Check the theme system status and review the requirements
Also WPML requriements
– https://wpml.org/home/minimum-requirements/
At least 128MB of WP-memory is needed, so you should set it as high as possible.
I have no idea, but when i disable wpml its saves
Then it is more likely that there are insufficient resources, increase them as mentioned. WP-memory can be set higher then recommended.
Hello;
i have increased resources for this. will give it a try
