Oct 8, 2021 at 4:46 pm
We are using Flex Block 3 and would like a Vertical Divider between Module 1 and Module 2. I am able to add a horizontal divider, but not Vertical on both modules. See video.
Mar 16, 2022 at 10:51 pm
Many thanks for your prompt reply.
1. for the hamburger menu, I reference that of The New York Times . See screencast image https://www.screencast.com/t/Y19esoJ4y
2. For the vertical border, I found a solution for it in one of the forums. Thank you.
Mar 17, 2022 at 9:39 am
Hello @roc-100!
You have 2 possibilities to build a menu like that:
1. Use Modals: https://forum.tagdiv.com/modal-popup/
2. Page mega menu: https://forum.tagdiv.com/page-menu/
Hope that helps you!
