Hi!
I have two licenses of your theme. why m not able to login too? what’s going on?
Site says to purchase theme. I already purchased. Please help me in urgent
Note : I did not do any changes recently.
this is really bad. Please kindly help me.
I disable your theme from file manager (Rename) Still m not able to login. M locked. Why you did like this? I purchased your theme.
At least give access to my wp dashboard. what is my wrong? I purchased your premium theme.
Site is not working. Even cant login to my site. It is firs time ever happening to me. I really lost my site users reputation.
Note : M not a developer, I just purchase your theme and running my site. So, Please understand my difficult time now. I’m help less.
I’m now disabled plugins and I got back my site. So, I should not use your theme? but i have a license. coz of your theme. I went under construction mode now.
I updated and installed all plugins for your theme. Site is back. But I just want to know. Why did put purchase license when customers entered my site? when i already purchased. I have screen shot. I will share. This will happen again?
Note: I checked in theme panel, It’s says ” Registered” now and before also same!
Screenshot :
Note : I have found why I’m not login to wp-admin that because one of my plugin that allow to login front end and prevent wp-login. So, locked out is not because of your theme. Sorry for that. But, Your theme blocked my site and shows as I send to you screen shot.
Please kindly give a complete guide for this error!. Because it should not happened in future.
This is a notice that appears on older theme versions unfortunately. Please update to the latest version and this issue is gone: https://forum.tagdiv.com/how-to-update-the-theme-2/
We recommend you to update via FTP.
Note : I have already updated. It’s says – Version: 11.2
M I updated already ?
I hope this is not what your website visitors are seeing as well? I understand that tagdiv needs to do something about illegal copies but this is a pretty aggressive measure as it is basically telling all your visitors that you are a “thief” even if you are a registered user and paid for the theme. If this could happen to registered users, why not have a basic error page instead with the message to contact the website owner with a email address?
We are sorry for the inconvenience. Please reset your key in System Status: https://i.imgur.com/Kw9qxic.png The issue should be gone.
