Hi, when I make a post on my site, the images get in the way of the embedded YouTube videos, it’s very annoying, in this last case being a YouTube SHORT, I solved it by modifying the URL, but the big problem is that now the video but won’t play it.
Print: https://i.imgur.com/IY1jEs5.jpg
Website: https://notevitricampeon.com/
I’m not sure that I understand correctly the problem.
Are you trying to set a post with a featured video and you are using YouTube SHORTs?
Can you please provide the steps you do?
first thanks for answering
I tell you what is happening to me, it is when I want to publish blog notes, that where I place the VIDEO module, when the note is published and I enter it, the images get in the way of the video and the texts too. (screen attached)
URL Post Web: https://notevitricampeon.com/2022/09/28/asi-esta-el-campo-de-juego-en-el-estadio-mercado-luna/
Regards,
It seems that this problem is only on mobile, on desktop everything seems to be ok. Also the post I believe that its made using the elementor -> https://i.imgur.com/wVGVu4p.png
Using the Newspaper theme we recommend to do not use extra builders for posts, only the WordPress editor (Gutenberg and classic editor).
Please notice that we do not tested the elementor with our theme, so we can not say if this is working correctly, also we can not interfere with it since it is a premium plugin.
