I see this topic has been asked several times. I need a response with a solution, please.
1. BOTH COMPOSERS ARE NOT BEING UTILIZED ON THE PAGE – please do not tell me to deactivate one plugin or another, since the theme relies solely on TD Composer yet my content relies on Visual Composer. They’re not being used at once on the posts or pages, so this isn’t a ‘solution’.
2. Please tell me where in CSS code I can remove this custom cropping that Newspaper or TD Composer is forcing upon my pages. When I say I want to add a single image in Visual Composer and put in a custom size, I need that custom size to work. I have multiple posts and pages this is happening to.
Again, I’ve searched for this answer in the forums and while there are several threads, all have the same response: deactivate one plugin, or the other. NOT A POSSIBLE SOLUTION. Just tell us where to modify the code, please.
I need to launch this site within a few days, so a timely response is appreciated. My last requests never even got a response.
Attached is a photo of the images. They are all supposed to be 100px in height, but something is overridding it, and I can’t seem to find where/what is causing this while using Inspector.
Thank you for your time.
That would be the only solution. Only one page builder should be active at a time. Single image elements are affected by both composers when they are simply active, they have a different functionality in each composer.
For example the tagDiv composer uses the image as a background in the single image. Visual composer single image has a different implementation. When both are active the single image will not display properly.
You will have to eventually decide on the composer you want to use, and deactivate the other. Simple as that. The tagDiv composer is considered the main page builder in the theme and it will receive many more features in the future.
Then you really shouldn’t market the theme on Themeforest as being compatible with Visual Composer. This isn’t ideal for people who are migrating from one theme to another.
The theme is compatible with Visual composer as it is provided in the theme package. You can choose from Visual composer or tagDiv composer.
Visual composer will still be provided in the theme package, although the tagDiv composer is considered the main page builder since it’s introduction.
A thing to note is that the tagDiv composer will receive a considerable amount of options and settings in the coming updates. These will not be available in Visual composer.
@kennytran We recommend to use the tagDiv composer with the theme. If you are asking if we tested our composer with other page builders, we have not.
Our page builder will receive more features in coming updates. Also if you want to use the cloud library plugin to benefit from the cloud templates, these will only work with the tagDiv composer
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
You can use the composer to create/import cloud post templates. This will require the cloud plugin. So you can create post templates and apply them to posts, not actual posts.
You can test the cloud library plugin live, choose to preview a post template and edit it here
– https://affiliate.tagdiv.com/#/load/Single
