Visual composer not working help ASAP
the editor showing the visual composer code i need to resolve this issue
Are you sure you are editing your page with the back-end editor and not the classic mce editor? Please make sure your visual composer plugin is up to date: and you use the back-end editor: http://screencast.com/t/DFlP1tCr20e
If you do not have the latest version of the plugin please use this guide: https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
