Visual composer not working HELP
Since last update in visual compuser it stoped working and now we dont have visual compuser option in the post or pages… I have uninstalled it, flush and installed it again but nothing change, I have installed pervius version of visual compuser and still nothing changed and its not working, please help
regards;
Reza
I found problem, unfortunately yoast SEO has conflict with visual composer :((( i need this plugin, please guide me how I have to fix, if its possible, I have premium yoast :(( .
when I’m deactivating it visual composer working great :(((
regards;
reza
Hello Reza,
The latest version of WordPress (4.5) ‘broke’ the Visual Composer and you need to update this plugin to the latest version of this (4.11.2) and then the things will be work as expected. Please check this tutorial before updating this plugin, here -> https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Alla plugins are updated , this sulotion work when you dont have yoast seo premium plugin !!!
Its working with free version but premium version has conflicts with visual composer.
I sent email to yoast hope they solve this problem, its a big problem for us.
When i activate premium yoast all visual composer option gone 🙁
Hello Reza,
Please keep in mind that you have to use only the plugins that come bundled with our theme because only these plugins are tested with the theme and work as properly. The premium version of Seo Yoast plugin is not tested with our theme and could create some errors through the theme. My advice is to use only the plugins that come with the theme for best results. If you want to make that this premium version of the plugin to work fine with the theme, please notice that you will have to adjust the theme to the plugin’s file and this involve custom work. If you are not aware of the steps which you needed in this regard, please consider hiring a freelancer/developer to help you because we cannot provide customization services at the moment, sorry!
Hi;
Thank you so much for your reply, Mmmmmm I didnt know I shouldn’t use YOAST SEO plugin, because its the best for SEO. so what you suggest us to use for SEO ?
if it’s possible please give me some hint what I have to do to have YOAST SEO, I’m sure its one the best Plugins in the market and your clients will use it.
I am highly appreciated for your time and assistance.
best regards;
Reza
Hello Reza,
Unfortunately, as I said you above, the premium version of SEO Yoast is not tested with our theme, sorry! We recommend using the free version of the plugin (v.3.1.2) because this version is tested with the theme and everything seems to work as expected. In your case is talking about the conflict between theme and plugins. As a suggestion, you can try to disable all the active plugins, leave just Visual Composer and your SEO Yoast Premium plugin to active, clear all cache and check if this plugin is working, otherwise please notice that we do not have the workaround in this regard, sorry!
Please keep in mind, that most often, these kinds of conflicts between plugins are resolved by the plugin’s author or these will be fixed in the future updates. As you can see here -> http://screencast.com/t/G17fxxmOzSpq the Visual Composer should be valid with all versions of SEO Yoast. You can try to contact the Visual Composer author in this case and ask them about this problem because they should be able to provide a more accurate response than our team.
hi;
Thank you so much for your reply, Actually i tried to deactivate all other than visual and yoast, didnt help, unfortunately there is a conflicts between these two plugins. already downgraded yoast to free version, its working, but I need to use premium version, I have to boost my SEO, may I ask you a question ? please. regarding this problem, you think this conflict is because of the theme codding ? or its between these to plugins ? I want to find the problem and try to fix. already sent email to yoast but they are to slow and didn’t get any reply 🙁 .
Best regards;
Reza.
Hello Reza,
Unfortunately, we do not have a workaround for you in this case, sorry! Please notice that is not a simple task to make it working this plugin with our theme because the theme will have to be adjusted and this require custom work. Please consider hiring a freelancer/developer to help you because we cannot provide customization services at the moment, sorry!
