VISUAL COMPOSER PROBLEM
Hi Team,
I’m creating a new topic as someone else stepped on my topic with their own problem. This is urgent and important.
PROBLEM:
When I go in to edit a page and use the backend editor (Visual Composer), none of the elements are showing. This means that I can’t make any changes to any pages!
ATTEMPTED SOLUTIONS
I have updated Newspaper to V6.7.2
I have attempted to update Visual Composer – Failed. Showing version 4.9.
Nothing else is working.
Please help.
same problem here after updating to WP 4.5
Baztiano I have just fixed it.
Try deactivating WP Bakery, then delete it and its files. The go to the Newspaper tab on your dashbourd>plugns and install and activate visual composer.
It worked for me, hopefully you’ll have the same luck.
Basically you need to update visual composer to version 4.11.2. the version is bundled with the latest version of our theme.
https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Cheers!
Hi Jean Paul,
That actually worked for me. Thank you so much!
