Visual Composer – problem with template feature
Hi everyone,
is it possible to use premium feature Visual Composer database? In preferences, I have non-activated Visual Composer, but there I read that plugin from theme is activated.
I need for example download template of contact-page from theme library in VC.
Thank you for reply.
Sincerely
mr. Joe
Hello Joe,
Notice that you can use the Premium Feature of Visual Composer but we cannot say for sure if these will work or not with the theme because these were not been tested with the theme, sorry! We recommend using only the Visual Composer version which comes bundled with the theme core files because this plugin has been optimized for our theme. We cannot provide support for other untested plugins.
Yes… I have VC from bundle from theme… but… Is it ok, when theme warning me about non-activated version?
Please ignore the Visual composer activation messages. The bundled version does not need any activation in order to be used
https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Access to the Visual composer template library is limited to purchased and activated plugin, not bundled versions.
