Visual Composer problems
I have problem with visual composer.
https://imgur.com/a/95Ed1ro
This issue usually happens when the HTML on the page gets broken. Please check the html tags on that page and make sure all html tags are intact.
Plugin conflicts can also affect the sidebars so please also test this without plugins.
Beside this one, you recommend to use tagDIV composer or Visual?
We recommend the tagDiv composer, this way you can take advantage of the multipurpose elements, the cloud library plugin and others more
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
Use it to create pages, post templates, category templates, author templates etc.
WPBakery can still be used with the theme and it will be provided and updated, just that the new features will not be possible with it. When both composers are active there could also be issues in some cases.
