I created a separate template for mobile phones, but it’s also displaying on desktop versions. I’m using the W3 Total Cache plugin, and I suspect it’s causing the mobile template to display incorrectly. Has anyone experienced this issue and can suggest which function in the plugin to disable so that the Newspaper theme correctly detects the desktop and mobile templates?
Hello.
Yes, this issue is caused by the cache plugin, please check this topic and try the suggestions https://wordpress.org/support/topic/caches-desktop-version-for-mobile-and-vice-versa/
Thank you for the hint. This post is from 3 years ago, so it doesn’t all add up, but I was able to force the template to load correctly. However, I’m having trouble refreshing the mobile version. On desktop the posts jump right in, but on mobile with a very long delay or even not at all.
I think that there is an object cache file https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
