We explain what happened. Before starting, a few years ago we bought the Newspapers theme but not the official store, but a third party that did not want to use it on their blog, but the surprise is that now that person also uses the subject, there is the possibility of buy a new license and cancel the old license?
We would not mind buying the new theme, but what we want is to maintain the design of the theme, it has taken us a bit to get it to this point!
Yes you can buy the theme from themeforest , and you can reset the password from system status https://www.screencast.com/t/rdjQDTbokwT
Install the theme will not change your design, only if you install, some demo, or you can make some update -> https://forum.tagdiv.com/how-to-update-the-theme-2/
Hello, thank you for your reply, I can only buy the theme and make an update on the subject that we currently have, we will not have problem with the activation key of the subject? We will not lose the configuration? Thank you.
Hello, we have already bought the new theme, we can update to version 9.1, we currently fear version 9, thanks!
Yes you can, first please make a full backup of your website, after that fallow carefully the guide for theme update.
