I am using the weather widget with OpenWeather API. I am running into an issue where the weather info pulled in is incorrect when the temperature is changed from Celsius to Fahrenheit. It appears that the conversion is causing an issue. It appears that all works from the API side. Maybe the widget is not using the correct parameter for the API call?
Please help, as I need to show the weather in Fahrenheit, but have Celsius for now to at least show something that is accurate.
I checked an API on the OpenWeather and for me, it works => https://www.screencast.com/t/QVRnYO5Oh -> https://www.screencast.com/t/E5sejQ3Kxc3n
This is our guide for weather => https://forum.tagdiv.com/weather-widget/
