web and mobile versions
I have a problem with a site I have made for a client: https://antiaging.si/
The site is very different on desktop and on mobile.
Footer:
– On desktop and mobile I see different footers (diferrent social icons, different links…) I have checked the preview on Tag Div composer /Manager/Footer/General- desktop viewport (and phone viewport)
I cant find where to edit phone view?
Page: on my mobile I see only Big Grid Flex 5 and Latest posts which is very different from Phone view on
Tag Div composer /Manager/Footer/General- phone viewport …
Thanks for help
Please deactivate the tagDiv mobile theme plugin.
Using our theme you can choose from 3 mobile versions
-> mobile responsive => https://www.screencast.com/t/oJ2ShOp47
-> mobile theme plugin => https://forum.tagdiv.com/the-mobile-theme/
-> mobile page => https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/
If you created the mobile pages with tagDiv Composer, then when you install the Mobile Theme plugin, your pages will be overwritten by the plugin (the mobile theme comes with its templates for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout, the page content is made without builders in mobile editor => https://www.screencast.com/t/xbgZG8kH also, the options that are provided to edit the mobile theme version are limited (this keeps the things simple)).
This is a video about Responsive Newspaper Theme, AMP & Mobile Theme, Mobile Pages & Templates -> https://www.youtube.com/watch?v=SpGkOnJeNZY
So, the mobile responsive is what you see then that you select the viewport on phone => https://www.screencast.com/t/matV17hH, so some settings may apply for each viewport(where is the border blue), and others are not(where the border is black).
The mobile page has the mobile templates from Cloud Library => https://www.screencast.com/t/YCcZ8rL8
Mobile responsive version of the theme and the mobile page editor can be edit with tagDiv Composer, the mobile theme plugin not.
For example, you can have the mobile theme plugin activate and use the mobile page/mobile responsive version for the homepage/pages, but for the categories pages/404 page you can’t use the mobile page/mobile responsive version if you have the mobile theme plugin activate.
So, if you want to design the pages with tagDiv Composer, you can use the mobile page or mobile responsive version.
Thanks, I deactivated the Mobila pLugin. But I still see the author of the post on my mobile. This shoul not be seen. And on preview on desktop it is not seen.
How can I manage that?
Kind regards
If you disable the mobile theme plugin, then disable also, the amp, because the amp works with the mobile theme.
ok, it worked, thanks
But how can I use mobile Plugin (I suppose it is good for the site) and the Amp?
It is no enough if I swich to mobile view on Tag div editor, since there I see different mobile view that it actually is.
As I said before, a mobile theme is a simple version for mobile. Please check the documentation provided above.
