Hi Calin,
Can you please check.
1. Theme version: 12.6.6
2. Webp format is generated by Ewww Image Optimizer as per your guide. But Lazy Load is disabled.
3. Theme Panel >> Block Settings >> Thumbs on Moduls/Blocks >> Use Webp Format enabled.
Issue: The system applies the Use Webp Forma option to Flex blocks, but does not seem to be applying it to the Posts Loop block. It still loads jpg instead of Webp.
(!) As previously discussed, this post is only for Calin.
Other TD team members, please do not respond.
Hi Alex,
Indeed, it seems that the option is not apply on flex loop, flex loop 2 and also on flex loop builder and flex block builder elements.
I added this on our bugs list and one of our developer will fix it.
Thank you for taking your time to let us know about this!
