What is the difference between a module and a block?
There’s modules everywhere in the theme and I’m not quite sure what they are.
I presume they’re excerpts from templates, but they’re not labeled this way (as blocks are).
Also, there are 25 styles of blocks when I attempt to add a new element, but only 17 block headers in the theme settings. Why?
Also, there are modules 1-19 and modules MX1-MX26. What are these?
Could you clarify the difference and how they’re used?
  • This topic was modified 8 years by cjs.
This is explained in the theme docs. Modules are a group of blocks. See the link to theme docs and peruse the sections to learn all this stuff. Ton of info there ??
Could you kindly direct me to the relevant URL?
COMMUNITY:
The below URL explains the relationship between blocks and modules.
https://forum.tagdiv.com/theme-blocks-modules/
Yep, and for those who can’t find the docs:
https://forum.tagdiv.com/newspaper-theme-documentation/
