Where to edit categories in footer? I assume this is widgets but a cannot locate theme.
In footer are more styles, some of them comes with a set content, in order to remove it you need choose a footer template that is empty and you can set in footer widgets with blocks that you want to show, for example -> https://www.screencast.com/t/wQnryIm1bo -> https://www.screencast.com/t/YIvVDaCIHyw -> https://www.screencast.com/t/2o0GOzaPU2
Footer templates documentation -> https://forum.tagdiv.com/footer-templates/
Ok, but I want to edit ‘Populære kategorier’ (popular categories) in footer. Categories I want to show is missing. How to edit this?
You need to change the footer for example footer style 3 -> https://www.screencast.com/t/A2OcwDtF9T go to appearance > widgets and add the category block in footer 2 or 3 -> https://www.screencast.com/t/xK7XmK10 -> https://www.screencast.com/t/IwR5ay9eRRI7 make the settings -> https://www.screencast.com/t/6CAvkShnHC -> https://www.screencast.com/t/wvlXJAmN1q alos you can set others blocks too.
