Why my POST SETTINGS panel is different, with LESS options?
Hi, guys!
I was trying to disable “show tags”. So I went to this post https://forum.tagdiv.com/search/remove+tag+from+post/ looking for some help.
But my POST SETTINGS panel is different, with less options. The “show tag” doesn’t appear to me.
So, first…
Why my post settings panel has less options?
Second…
How do I disable “show tags” on my posts?
Here is my panel
Panel
Panel
Please activate the tagdiv Standard pack plugin if you use standard template, if not, then you need to add the element from tagdiv Composer, in the single post template.
Thanks, Anamaria!
I’ve found it!
I’m glad.
Have a great weekend!
