Woocommerce problem
I use woocommerce on my newspaper site – but after having upgraded to the latest version of newspaper, woocommerce category pages aren’t displaying products on them. We’re getting the following error:
“Fatal error: Call to undefined method td_page_generator::wrap_start() in /home/billyscr/public_html/ukstaging/wp-content/themes/Newspaper/woocommerce.php on line 61”
Is this something you can help with please?
Please note that Newspaper 8 doesn’t contain any woocommerce.php file like referring to in the error path. If you updated from an older version make sure the theme is updated properly. Update the theme by FTP
– https://forum.tagdiv.com/install-via-ftp/
Also if you had custom modifications in code for the older version, you will probably need to modify the code and make it work also for Newspaper 8, or test without them. Do not use older codes or modifications as they might need adjustments.
The latest theme version 8.1 works properly with the Woocommerce plugin, there have not been other reports in this matter.
