Hi the WP editor wont load within Text with Title module on my site. I have disabled all plugins apart from tagdiv, and it still wont load. Tried checking system settings for the theme and all requirements are met. Could you please advise?
Thank you in advance
Rachael
Hi Rachael,
Please check the console when you open edit content; if there is an error like this, please go to the Network tab, select the error, and select Preview -> https://i.imgur.com/iiBOHwP.png
Maybe the problem is caused by the server host
I think you will have a 403 or 404 error, so please check this topic -> https://forum.tagdiv.com/topic/wp-editor-for-text-with-title-and-column-text-not-updating-content/ and try the suggestions. Also, please check the cache, clear/purge all cache.
Please check this topic with the same error https://forum.tagdiv.com/topic/err_http2_protocol_error-on-go-daddy-hosting/
