Wrong posts counter
Dear Team,
I saw an error in the counter of the post.
This post is just posted and on g-analytics I dont’ see those numbers
This in an example https://www.intrieste.com/2022/03/07/news-coffee-time-07-march-2022/
The counter is near the comment, top right, I just use via stylecss the white color to not show it.
Can you help us?
Just an update: I just enabled the AJAX and USE LAST 24/48 HOURS & 7 DAYS POST SORTING & I’m using WP SUPER cache plugin
  • This topic was modified 4 years by Flash83.
Hello @Flash83!
Please make a test and deactivate ALL plugins except tagDiv ones, also deactivate the cache plugin that you use, and try again in an incognito tab.
Check this guide too: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Let me know the results!
Hi Bettina,
It’s quite complicated to disable all the plugings of a live website.
I checked the link and the configuration of YOAST.
When I disabled all the plugin except yours the number of the visit are the same as before…
I suppose that the counter will not start from 0 also If I disable everything, so probably after disabling I have to create a new post and see if the counter starts from 0?
Any other solution to hit the right point?
Hello @flash83!
We can take a look for this and investigate why is not working for you. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– cpanel url and credentials
Maybe I find the issue!
For those kind of posts I’m using a plugin called Duplicate post, so I can see that it’s an incremental count from the first post that I duplicate…
Do you have any tips to solve this issue? I like to duplicate the post because save me a lot of time
Hello @flash83!
Please check this article, disable the option and see the results: https://forum.tagdiv.com/unique-articles/
