YOAST SEO plugin with products pages created with Woo Product templates
Dear Support,
How to use YOAST SEO plugin with products pages created with Woo Product templates?
Site: https://elektricnibicikli.rs
Prebuilt Website Installed:
Shop Vintage Choppers Store
Product pages:
https://elektricnibicikli.rs/product/tricikl/
https://elektricnibicikli.rs/product/skocko/
https://elektricnibicikli.rs/product/povetarac/
When edited those pages I have
product content template not set!
SEO: Not available
Readability: Not available
Thank you in advace.
Best Regards
Hello @platamun47!
In the Yoast SEO plugin settings, you should have the “Products” section and also the “Cloud Templates”: https://yoast.com/product-page-seo/
Dear Bettina,
I have the “Products” section and also the “Cloud Templates!
Would you be so kind to check why product has messages product content template not set! whet edit the product page.
You have admin parameters of our site…
Thank you in advance.
Hello @platamun47!
I can see that you have the Woo product template (Delovi Global) assigned to your products and other different templates. Please check the SEO settings from Yoast SEO -> Settings -> Products & Cloud Templates. Also, if you edit a product (Gutenberg), scroll down, and you can see the most recent SEO settings.
The product content you’ve set in the tagdiv composer in the cloud template.
Dear Bettina,
thank you for your message.
When I edit (clasic edit) product page, I do not have any text
and down of page I have SEO analysis.
This is one of more line with red light:
Text length: The text contains 0 words. This is far below the recommended minimum of 300 words. Add more content.
Where is my text of product. Text of product is created over Tdiv editor.
My product has text on page, but SEO plugin does not see that text.
If you need information of this problem, please let me know.
Hello @platamun47!
Yes, because you added the text in the TagDiv Composer. You can add the same text there too for every product.
Dear Bettina,
If I understood, please check me…
Pages of products created with your woo template, edited with TagDiv composer does not see SEO Yoast plugin. I must edit products page with wp editor and add same text to have SEO full settings. What is about images, alt descrip, etc…Is that possible to correct work SEO engine from google or other…
How you imagine to work all with that settings…
Hello @platamun47!
We have special shortcodes for the woo shop templates: woo page title, woo product description, woo product image,etc. https://forum.tagdiv.com/tagdiv-shop/
Dear Bettina,
Please tell me what is with text added in exist products pages
(created with woo template)
That text on products pages SEO plugin does not views…
I try add woo elements to products pages, but I can…
I do not have green field in empty row, when I try to add woo element…
Thank you for your help.
Hello @platamun47!
Yes, you have woo templates, but not woo elements. You can easily drag & drop any element in any row.
Dear Bettina,
