Ok Calin. Got it. Thank you for the update. Appreciate it.
Ok. Disabled WP Bakery Plugin and then it worked. What’s the root cause and how do we make things compatible? Because WP Bakery Plugin comes as an optional suggested plugin in Newpaper’s own dashboard isn’t it?
Sent all details via email. Please check and help fix.
Have sent you all screenshots and credentials via email. Please check and revert.
Pls help
