I found the errors in my Google Console
Hi Calin,
Well, the issue was there before and after I activated the plugin, so it doesn’t make much difference.
thanks for the reply. So if those are just improvements, can I deactivate the Jquery plugin?
Hey Calin,
It’s still not working after activating the plugin and I also cleared all the cash.
https://www.screencast.com/t/IGsKVUvO
https://www.screencast.com/t/l2UXyLO4
https://www.screencast.com/t/Kcm4jv0M8yA
https://www.screencast.com/t/6a7WkliiZ
This reply was modified 5 years by
cruising-sea.
Hi Calin,
I have activated this plugin and I still face the same issue. Now it’s even worse. They are files missing in the theme. Google refuses to index my posts.
Please, check those screenshots:
https://www.screencast.com/t/w4s4Dol4u
https://www.screencast.com/t/UBr9n23r3
https://www.screencast.com/t/OlZblIUzy
https://www.screencast.com/t/fgDD0hAyY
Hey Simchris
Thanks for the reply!
So I have to wait until TagDiv release a new update:)
Hi Calin,
Thank you for your reply!
Ok, great!
I used to get notified via mail when the support response. Why not anymore?
Thank you, Calin! it works great now!
Hi Calin,
Thank you for the quick reply. I meant in the footer, not at the top or bottom of the post. There, the buttons show. Please take a look at it yourself. https://cruisingsea.com/
Thankyou!
Superb support, thank you! You are the best!
Now it works fine.
Awesome, it works like a charm now:) Thank you!
Hi Catalin,
Yes sure. Here is the page. https://cruisingsea.com/tagdiv-composer-draft/
Hi Calin,
That’s awesome! Thanks a lot!
Hi Calin,
Thank you for the quick reply!
Hi Gooma2
Yes, I’ve checked in the old version. I don’t have any problem there.
I just don’t understand what is this error? http://www.screencast.com/t/QsdvU3UG
I have a feeling that this is what causes the issue with the rich snippets.
Hi Calin,
My rich snippets used to show on Google, but suddenly all my rich snippets disappeared.http://www.screencast.com/t/NnMKw5BvR7F0 I checked on Webmaster Tools and there is nothing wrong. I checked with my hosting company and there is nothing wrong either. So today I opened the ‘Inspect on my article and I found an error. http://www.screencast.com/t/QsdvU3UG
This never happened before. Is it possible there is a code missing or a code error?
http://www.screencast.com/t/8e5IB0qfDxei
Thank you again!
Hi Calin,
I went to the library but I don’t regenerate thumbnail : http://www.screencast.com/t/0c5k4qzY
Hi Simion,
The problem is resolved! Thank you!
I’ve rectified the link and it’s still doesn’t work
Hi again,
I got it now!
I made the change, thank you!
Hi Catalin,
I don’t understand what you mean. I have never had this problem before. It happened when I uploaded the latest version. I don’t any difference in the link!
I don’t think so. I did exactly what is suggested!
On some pages, it works and on others, it doesn’t. https://cruisingsea.com/
